Downloading the New .Net POS Demo Software.
Postby basit » April 20th, 2008, 10:04 pm
The Full Enterprise version of the CompuByte POS Net software is available for download from the link below:
http://www.compubyte.co.za/updates/setup.exe
Size of file 90Mb - Time with ADSL internet 30 to 45 minutes
Important : Depending on your browser security you may have to right click on the link(s) above and click on Save Target As then type in setup.exe and change Save as Type to All files.
Once downloaded double click on the file.
Important : Crystal Reports may ask you for insert Product ID ; just leave as blank (dont insert anything) - On some versions of windows ; Crystal Reports may come up with an error (on registration) just click on Ignore . .
Once you open the CompuByte program the operator number is 1 and the default password is 1234
If you don't have a fast internet connection you most welcome to request for a free CD's (with visual tutorials) from our office or email your address details to us . .
Why is the install files so large ?
Postby basit » December 30th, 2008, 10:57 am
Unfortunately we choose to use the best package available for true intergrated reporting for our .net software ; while the software we wrote is very small 4mb the crystal reports and .net framework is large over 75mb . .
Thats why we like clients to just pick up a demo disk with all the files or email us their address and we will post at no cost . .
Vista Security
Vista often prompts you to allow certain programs to run (and it can be irritating ; specially when you know you want to run the Compubyte .Net POS version :) ) ; We recommend that you disable UAC ; to do this :
1. Open Control Panel.
2. Type UAC in the Start Search box.
3. The first link that appears should be Turn User Account Control (UAC) on or off. Open it.
4. Uncheck Use User Account Control (UAC) then click OK.
Restart the computer and UAC is disabled.
Hope this helps
Re: Downloading the New .Net POS Demo Software.
Postby basit » September 17th, 2015, 12:24 am
Latest updates are now auto sent to users downloading the software !
Postby basit » September 26th, 2015, 8:53 pm
:arrow:
Users browsing this forum: No registered users and 2 guests
