Connecting to Branches.
Post by bossalino » February 11th, 2008, 9:40 pm
Could you please explain to me how to create the cw.bat file for connecting to branches. i need to redo this at all the stores as they not yet using the .net and i need to transfer stock to other branches. i could do it through the .net but this means it needs to be done manually. i know what commands to fill in, i just need to know how to create it.
Thanks Zaki
Post by basit » February 13th, 2008, 7:32 pm
Below is a typical cw.bat file.
Change the drive letters and IP's based on you VPN (hamachi)
DEL C:\RAM\IP.
SUBST X: C:\RAM
NET USE H: /D /Y
NET USE H: \\5.65.230.214\Compu /Y
NET USE M: /D /Y
NET USE M: \\5.65.234.143\Compu /Y
NET USE L: /D /Y
NET USE L: \\5.66.208.94\Compu /Y
NET USE E: /D /Y
NET USE E: \\5.74.94.22\Compu /Y
PAUSE
Hope this helps
Please not the \Compu is the drive you sharing ; in your case if the drive is shared as C then it would just be \c
BASit
Branches
Post by bossalino » February 13th, 2008, 8:05 pm
I found in the latest update the start up file has that info in it and it now solved the problem. I just had to correct the drive letters and the new vpn numbers in it and it now connects the moment the dos programs is opened.
Thanks :D
