Using equal sign for fast data input at PLU
shamshoodeen
Postby shamshoodeen » October 7th, 2015, 1:10 pm
To create the file do the following:-
At the PLU you press the equals key (=) ,Right click on the mouse on the white block that comes up,It will then open up a notepad which you can enter your fast data input example: Software ,And if you want to edit the name and the price and quantity to your quick input PLU data than you should add a ( /)
example: Software /
If you add a double // you will be to edit only the price and unit not description
example: Software//
If no slashes are used after the text the complete text will be used without any edit prompts.
To use the file do the following :-
Just press the equal key at PLU prompt and select the desired option from the drop down by clicking on it or pressing enter on the choice.
Users browsing this forum: No registered users and 0 guests
