A4 Printers(USB) not printing from compubyte
Postby muhammed.patel6005 » September 29th, 2015, 10:00 am
If you are able to print a test page and in quick setup the correct printer port is being used but still does not print from compubyte then do the following:
    1) Check if DOSPRINT.exe (Application) files in C:\Programs exist.
    2) If the above file cannot be found you can download it from http://www.compubyte.co.za/updates or call compubyte support 011 791 5063/3763
    3)If you are running an anti-virus please ensure that you do not allow it to delete DOSPRINT.exe file
