Tracking stock
Tracking stock
Postby muhammed.patel6005 » September 10th, 2015, 9:10 am
To view all details relating to a particular stock item you would do as follows.
1) Search for stock item at PLU code or insert PLU code.
2) On the left hand side of the log off button a stock info table should appear with an Anal-Stock button which should be used to view all details for that particular item.
3) You may also right click on the stock item after searching for it and select view quick stock analysis.
