- 1) Map terminal to server using NET USE COMMAND e.g
2) Search for the compubyte setup file mainly found in compubyte directory or local root directory. If not found go to http://www.786.co.za and download setup file.Code: Select all
net use P: \\server name\c /user:username password /persistent:yes
3) Install compubyte as well crystal reports ( At crystal reports leave product key blank)
4) Ensure that compubyte updates to latest version
5) Point compubyte to server using "Change data drive and terminals" button
- Add drive letter of server in correct textbox to point compubyte to server
Clean install of compubyte software on a terminal
muhammed.patel6005
