How to retain Hamachi IP and configuration
Post by basit »
UI CONFIGURATION
1. Go to control panel and show hidden files and folders
2. Navigate to c:\users\user\AppData\local
3. Inside the local folder copy the LogMeIn Hamachi folder to the desktop as LogMeIn Hamachi-UI
SERVICE CONFIGURATION
2. Navigate to c:\windows\ServiceProfiles\localservice\AppData\Local
3. Inside the local folder copy the LogMeIn Hamachi folder to the desktop as LogMeIn Hamachi-SERVICE
Once Done, the following needs to happen:
1. Uninstall Hamachi and remove all user settings
2. Clean install the latest Hamachi
3. Log in to your account and make sure it generates an IP
4. Close down Hamachi and fully exit Hamachi from the action centre
5. Go to services and stop your LogMeIn Hamachi service.
Inserting UI back
1. Navigate to c:\users\user\AppData\local
2. Inside the local folder delete the LogMeIn Hamachi folder and copy from the desktop LogMeIn Hamachi-UI as LogMeIn Hamachi
Inserting SERVICE CONFIG back
3. Inside the local folder delete the LogMeIn Hamachi folder and copy from the desktop LogMeIn Hamachi-SERVICE as LogMeIn Hamachi
Go to services and start your LogMeIn Hamachi service.
Now open Hamachi and power it on.
Wait for it to load your original IP settings and groups.
