In order to configure the compubyte software for restaurant purposes, please follow the following steps:
Step 1: installation
install the compubyte software.
after inputting company details set the store type to takeaways/restaurant
step 2: configuration
open the parameters and configure the following entry number:
414 - insert 1 here to activate the restaurant module
217 - Insert the port number of the kitchen printer e.g LPT2
226 - insert the required size you would like to display for the menu images, 3 is the recommended image value
228 - insert the default group number to display the pictures , default would be group number 2
233 - insert 9 to set the default document module to load as order from customer, so that the program always goes back to this module after a sale
step 3: stock loading and setup
enter the goods receiving module , select new stock item, then new group and create your groups as follows:
group 1 : raw materials -this group must contain all the raw materials used to create a dish eg. eggs, meat, rice ,etc.
group 2 : tips -this groups is compulsory as it used to calculate and monitor waiter tips automatically, this group should contain a code for each waiter serving tables. e.g 2-1 = muhammed
group 3+ : these groups serve as your menu item categories e.g starters, mains, desserts
you may now begin adding stock items to your groups using the relevant fields below group selection, remember to capture images for your items or browse to add existing pictures for them. make sure you click the update button after each menu item.
once all your items have been added into the relevant groups , you can now select main menu on the top left, scroll down to setup graphic stock pics, follow through the prompts and a notification prompt will read done!!
as a result of the above you can now use the right arrow at the plu screen to list the menu categories and display its relevant picture.
step 4: using the restaurant module for sales
upon login of the program,you will be at the order from customer module with a list of table numbers underneath the accounts.
here you will choose the table number that is placing an order.
the table will be flagged as open and you can then build your order.
once you've ended the document, one slip will print to the kitchen and the other for the customer.
when the customer is ready to checkout.select the table number again and it will automatically convert it to a sale, add the waiters tip using a code from the tips group depending on the waiter and then proceed to ending the document.
for information on how to monitor the programs,waiter tips,financials etc. please contact our support line on 0117913763 and we will be glad to assist.
Installation of CompuByte POS software for Restuarants
muhammed.patel6005
Jump to
- .Net CompuByte POS now available here ! ! !
- ↳ Registering on this FORUM
- ↳ Preview and Review of the Latest CompuByte POS .Net Software
- ↳ Video Turorials and Full Printable Manual - Great way to understand and learn the .Net POS Software
- ↳ Quick Pricing - Minimum Requirements for CompuByte
- ↳ Updates Information - .Net POS - "Simplicity is the ultimate Sophistication"
- ↳ New Address and Map: - CompuByte - Randburg
- ↳ How do I download the release version of CompuByte .Net POS Software - Plus Questions - Reviews and Comments . .
- ↳ CompuByte POS .Net Frequently Asked Question (FAQ) (Only new windows .Net Version)
- ↳ Daily Support Queries
- ↳ Adding a new PC and connecting to CompuByte
- ↳ Setting up an Ubuntu Server
- ↳ Zillion, Trillion, Billion or Million how much can CompuByte handle ???
- ↳ Time to relax and Enjoy Tetris and Win ! Win ! Win !
- ↳ Rani Group Namibia - Support
- How To Use This CompuByte Support Forum
- ↳ Your comments about this Forum
- ↳ Important Individual Downloads (OLD DOS VERSION)
- ↳ CompuByte Training - FREE to CompuByte Service Contract Clients
- ↳ .Net CompuByte Support - F A Q
- Newest UPDATE's Downloadable here for CompuByte POS (DOS version)
- ↳ CompuByte POS Updates for Service Contract Clients Only
- Detailed Information on Monthly Updates For The CompuByte POS Dos Software
- ↳ January 2006 to April 2007
- ↳ November 2005 / December 2005
- ↳ September / October 2005 (Update Information)
- ↳ August 2005 (Update Information)
- ↳ July 2005 (Update Information)
- ↳ June 2005 (Update Information)
- ↳ May 2005 (1)
- ↳ May 2005 (2)
- ↳ April 2005 (3)
- ↳ April 2005 (2)
- ↳ April 2005 (5)
- ↳ April 2005 (4)
- ↳ April 2005 (6)
- ↳ April 2005 (7)
- ↳ April 2005 (8)
- ↳ December 2002 to March 2005
- Your wish list
- ↳ Report and Discuss BUGS in The Beta Version .Net
- ↳ Reports and discuss BUGS in the DOS version
- How to use the CompuByte Software (DOS)
- ↳ Your Criticle Comments
- FAQ - Frequently asked Questions (OLD DOS VERSION ONLY ! ! !)
- ↳ This is where you will find most frequent questions asked about the CompuByte POS Software (DOS VERSION ONLY !!)
- ↳ General Members Forum - Anything but compubyte support.
- File Sorter -Programmers Forum
- ↳ File Sorter
