A few simple steps to set up your Ubuntu Server
Some quick notes on setting up an Ubuntu server
Post by basit »
Installing Samba Server
** Download ISO for DVD from this site :-
http://www.ubuntu.com/download/server
Burn ISO to CD or DVD
1) Use DVD and install - don’t use DHCP (dont connect your Server to the internet) – manually install IP - name the server SERVER - Install only SAMBA on the server.
2) at terminal prompt type in :- Sudo nano /etc/samba/smb.conf
3) Edit the file by inserting the following
[C]
comment = Guest Share
path = /share
browseable = yes
read only = no
writeable = yes
guest ok = yes
press [ctrl] and X to save the file then type in
4) Sudo mkdir /share
5) Sudo chmod 777 /share -R
6) Lastly in compubyte on each terminal at network setup up (log in screen) insert drive letter f and at map insert \\SERVER\c
thats it ! :wink:
On line to speed up an Ubuntu server
Post by basit »
at terminal type in the following :-
add this line :-
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=65536 SO_SNDBUF=65536
Then [CTRL] and x to save file
Setting Hamachi for Ubuntu ~
Post by basit »
http://www.iceflatline.com/2009/10/remo ... i-and-ssh/
Only installation of Hamachi i did differently
sudo wget https://secure.logmein.com/labs/logmein ... 1_i386.deb
sudo dpkg -i logmein-hamachi_2.1.0.119-1_i386.deb
or on a 64 bit:
sudo wget https://secure.logmein.com/labs/logmein ... _amd64.deb
sudo dpkg -i logmein-hamachi_2.1.0.119-1_amd64.deb
To ensure that when Ubuntu is rebooted and hamachi starts up insert the following line in the file /etc/rc.local by doing the following.
sudo nano /etc/rc.local
insert this line in
sudo /etc/init.d/logmein-hamachi start
Re: A few simple steps to set up your Ubuntu Server
Post by basit »
:arrow:
Return to “Setting up an Ubuntu Server”
