Linked codes - Case lots and loose items (Mutiple packaging)
Post by basit » May 21st, 2013, 11:42 am
linked code for case lots etc:-
Eg : Code 1-1 has this in description: Case of 12 Cokes cans = 12
Code 1-2 has this in description: Case of 6 Coke cans = 6
Code 1-3 has this in description: Coke 500ml =1
Code 1-2 - Parameters field must has: [>1-1
Please make sure you have the square bracket i.e [
Code 1-3 has this description: Single Coke Can =1
Parameters field must have: [>1-2
When there is no single cans, the program will take 6 cans from code 1-2, when 6 cans are out of stock the program will take 12 units out of code 1-1 and divide that by 6 to replenish stock.
