Employee management - Times Login and Logout (CTRL E)
Post by basit » April 18th, 2012, 4:44 pm
If you require to monitor the times your employees login's to work and log'sout you can set paramater 265 to 1.
From tools you can than choose Employee Management - then insert all the employee details and times they work.
Now when ever an employee Logs In or Logs Out they have to press CTRL and E keys . If you have a web cam it will also take a pic of the employee.
You can see employee time reports in the Reports section.
