Laybye Update
Laybye Update
Post by bossalino » May 3rd, 2011, 2:40 pm
WHat exactly happens when the option to re use old happens is clicked?
What clears up?
Re: Laybye Update
Post by basit » May 6th, 2011, 1:12 pm
bossalino wrote:WHat exactly happens when the option to re use old happens is clicked?
What clears up?
All that happens is that the system checks old lay-buys and flags all lay-buys that has been paid and taken so that the same account numbers can be re-used. If this is not done the lay-buy accounts will just continue to grow.
Post by bossalino » May 10th, 2011, 7:45 pm
Thats a wonderful idea.
