Pole Displays showing sometimes garbled(garbage)
Postby basit » August 5th, 2019, 10:38 pm
If you have a Pole display and it sometimes shows garbled characters you may have to go into your device manager and under the port where you set the baud rate etc for the serial port under port settings FLOW control must be x-on / x-off.
