Linking branches with compubyte POS and HAMACHI VPN
muhammed.patel6005
Postby muhammed.patel6005 » October 14th, 2016, 2:52 pm
Linking Branches Using Hamachi and CompuByte
Step One
At Head Office:
1. Download the Hamachi at http://WWW.VPN.NET
2. Create the group name at head office for the network in Hamachi e.g. (Subwear)
3. Share your data drive and give full control permissions
4. Make sure all your windows sharing are on
At Branch:
1. Download Hamachi at http://WWW.VPN.NET
2. Join the group that was created at Head office (Subwear)
4. Make sure all windows sharing are on
Step Two
At Head Office:
1. Open new text document
2. Type the following:
Rem Connect To Branch config
Net use b: (data drive letter) /d /y
Net use b: \\(hamachiIP)\C /user:admin 1234 (remote account details) /persistent:yes
Pause
3. Save as Connect To Branch.bat
4. Save as All File types on the desktop
5. Double click Connect To Branch.bat and check if the command is completed successful
At Branch:
Rem Connect To Head Office
Net use H: (data drive letter) /d /y
Net use H: \\(HamachiIP)\C /User:admin 1234 (remote account details) /persistent:yes
Pause
3. Save as Connect To Head Office.bat
5. Double click Connect To headoffice.bat and check if the command is completed successful
Step Three
At Head Office
1. In CompuByte, open parameters
2. Set parameter 112 by entering company numbers of which stock is to be viewed e.g. 1/2
3. Set parameter 201 and insert company number and drive letter matching for each company e.g. 1=c 2=b
4. Set parameter 273 and insert \EXPORTS for when retrieving documents from branches
5. Log in compubyte and go open a new Account in account sales for the branch as follows:
- Company name <BRA [B:2 [A:3 (Where (3) is the corresponding account from the branch)
6. Go open a new account in Goods Receiving so that you can receive stock from the branch, open the account as follows
At Branch
3. Set parameter 201 and insert company number and drive letter matching for each company e.g. 1=h 2=c
4. Set parameter 273 and insert H for when retrieving documents from branches
- Company name <BRA [B:1 [A:2 (Where (2) is the corresponding account from the Headoffice)
Users browsing this forum: No registered users and 2 guests
