Toggle on or off or disable Login Screen sound
tsebigmax
Post by tsebigmax » November 2nd, 2009, 1:36 pm
Is there a way to disable the laser sound that plays when you open the Compubyte login screen? I don't mind it terribly, it's just that it plays very loud on my speakers (and I sometimes have to explain to customers that no, I'm notplaying Star Wars :mrgreen:
Your trucking partner!
more info -------> http://tr.im/bm
Post by basit » November 3rd, 2009, 9:52 am
Will look at removing the sound if a few more customers complain about it :wink:
Most clients love the sound *hehe*
tsebigmax
Post by tsebigmax » November 3rd, 2009, 10:03 am
Well, you don't have to remove it completely. A toggle would be fine. Or even just a way to drop the volume on the sound elements. Also, the 'beep' that sounds after entering anything in fields in the modules.
Re: Toggle on or off or disable Login Screen sound
Post by basit » September 19th, 2015, 5:11 am
A new parameter has been set to disable all sounds :-
Set Parameter 368 (set to 1)
