Deleting a Company on the Logging Screen
larissa
Post by larissa »
When you want to remove any company on the logging in screen which is no longer in use.
First thing you do:
Click on start –all programs – Accessories – Command Prompt
In black box type the following in :-
Code: Select all
del \programs\per.0
(where .0 is the company number you want to delete)
When you go back on the logging screen the company will be deleted.
