How to view Quotations that you have made
larissa
Post by larissa » August 19th, 2009, 9:43 am
When you made quotations and you want to view them in details
On the POS program you go & click on Reports, scrool down & click on Stock Analysis Reports.
Insert the access code & press enter.
Select the specific date you want till end date, wait for few seconds while its still loading the Database.
When its finished, type in QUO in a textBox below Groups & press Enter. All the
Quotations you made will appear.
You can also click on Enlarge Analysis
tsebigmax
Post by tsebigmax » November 2nd, 2009, 3:12 pm
If you're looking for a QUO made for a specific client, you can go into any module, call up that client's account, then click [View Acc]. Choose your search criteria, then sort the report per preferred column. Piece of cake.
Your trucking partner!
more info -------> http://tr.im/bm
