faxing facility
faisal
faxing facility
Post by faisal » July 25th, 2009, 9:00 am
iv noticed that wheneva you reach the end of a document you have the option to fax it as well. how do you enable this
larissa
Post by larissa » July 27th, 2009, 2:32 pm
You can use fax in the Compubyte Innovative Software to send all documents to your customers from the program like invoices, quatations etc....
The first thing you do, You connect the fax modem to your computer and install it. When its installed properly you edit your customers Account details & insert the (at) sign before the fax number then update. When ending your document click on the box for send fax & end your document, it will automatically send the fax to your customer.
faisal
Post by faisal » July 29th, 2009, 12:00 pm
can you get me a price on the fax modem please!! and do you know what the costing is for sending faxes
larissa
Post by larissa » July 29th, 2009, 4:00 pm
Hi Faizal!
The Fax modem only costs 240.00, You also need to have a fax line & the Windows XP Service pack2 disk.
Tobi.
