expired laybuy
faisal
expired laybuy
Post by faisal »
how would i put the item back into stock. i've tried jus entering a '-1' in the quantities box but it corrupts my stock
Expired Lay Buy
Post by takalani »
If you need to put back stock for expired Lay Buy, you go to Main menu by pressing F4 key and select Lay Buy, on Lay Buy information window you insert -3 to delete a Lay Buy then isert the lay buy number to delete.
You can press Enter to keep deposit or insert 1 to delete 10%
Then you End the document, the item will go back into stock, just by deleting a Lay Buy
faisal
Post by faisal »
thanks alot bro. works like a charm
