Changing of Level Passwords -- And functionality
Post by takalani » May 20th, 2009, 4:36 pm
Click on the CompuByte Innovative POS Software icon.
On the login screen, click on Password/operators
Please the highest level is 10 and if you have level 10 password you can access anything that require a password ; So if you have level 7 password you can use it if any password is require for level 1 to 6
Then go to the specific level that you want to change.
When changing any level password e.g Level 7, then all above levels (8 / 9 /10 ) also need to be changed in order for that level to work properly.
