how to remove duplication of stock item on compubyte program
larissa
Postby larissa » May 14th, 2009, 12:15 pm
Right click on your compubyte innovative program and click open. when opened put in your operator number and password and Choose any menu on the main menu screen, click on tools scroll down and click on reindex stock item to remove duplication. Put on the access code, click on redo indexes and click ok on the info box that will appear written done you can close the redo index box.
Now all the duplications will be removed !!
Duplicate codes occur if you do frequent editing in the stock package without using the space bar to clear a discription ; using back space etc.
Users browsing this forum: No registered users and 2 guests
