How to set maximum discount allowed in CompuByte POS
Post by takalani » May 14th, 2009, 11:28 am
On the Login screen, click on Parameters, then go to Entry number 63, and on Data for this Terminal you insert the maximum discount allowed eg: if 10% discount is allowed without the prompt of the password, you'll insert 10**7.
This tells you that if a salesperson is giving discount, the maximum discount he/she can give is 10% discount.
If she/he want to give a discount of 11% and above, he/she must have the level 7 password.
Please note : You can have a higher or lowet level of access by replacing **7 to **10 etc
