How to do a month end report
larissa
Postby larissa » May 7th, 2009, 10:05 am
Open the compubyte program and put on the operator number and password and press enter. On the Main Menu screen you can choose any icon menu, go to main menu & click day end report right next to day end report click on the month end procedure and put on the access code which is normaly 1234. Select the dates from the beggining of the month till the end of the month click on okay then your month end report will appear.
Note:The month end report can only be done at the end of the month.
