How to reprint/ just print Labels on CompuByte POS
Postby takalani » March 19th, 2009, 1:27 pm
On the CompuByte POS program, go to Goods Receiving, then click on Retrieve Doc No, insert the document number that you want to reprint, then press Enter. Insert 1 and press Enter to reprint the document, then End the document, and it's gonna reprint your labels.
If you want to just print the label, you'll go to Order with Supplier, then insert -1 for Quick labels and press enter, insert item to do quick label, the End the document, then you print out you labels
