label reprint
faisal
label reprint
Postby faisal » March 11th, 2009, 2:58 pm
how do you do reprints of labels in .net version
which function is similar to quick labels generation on the dos version
Labels
Postby bossalino » March 12th, 2009, 5:45 pm
Try going to document type order with supplier . In the pop up box enter -1 for quick labels. Input what you need as if doing a sale or grn, end the document to print labels. Make sure the don't print label box is not ticked. and at number of till copies press right arrow :arrow: and insert Y. press enter and the label should come up.
faisal
Postby faisal » March 13th, 2009, 9:03 am
thanks for the info zaks. much appreciated!!!!
Postby basit » May 14th, 2009, 10:27 am
What will I do without you Zaki :-)
:x
Postby basit » May 14th, 2009, 10:29 am
:cry: <---------that face was for faizal as he did not tell us which company he is from !
