How to create Carton Matrix for Stock Item
Post by takalani » February 3rd, 2009, 9:33 am
On your CompuByte POS program press F4 to go to Main Menu; On Main Menu screen select Goods Receiving.
On your Goods Receiving screen click on New Stock Item[F6], now your on New Stock window:
Select the Group or first create a group you want to work on, then click on New Matrix button,
Then create your carton matrix there e.g A=5x2/6x3/7x3/8x4
You can create your Cartons from A to Z, with size matrix and number of size's you have in a carton.
