An ERROR! after downloading updates from the Internet
Postby takalani » January 30th, 2009, 4:46 pm
If you download CompuByte updates from the Internet to your memory-stick, and install the updates.
Then After Installing the update; you find that your CompuByte program is not Opening, and it's asking you to call Microsoft;
You must do the following:
- Click Start, On the Start Menu click Control Panel
- Then double-click on Add or Remove Programs,
- Click on CompuByte, then click Remove;
You can also use the windows explorer and find the folder program files in this folder you will find a directory called compubyte delete all the files in this folder C:\Program Files\CompuByte
The again click on the pos-upd.exe file you have on your flash or on the desktop
Users browsing this forum: Google [Bot] and 1 guest
