How to set Font Sizes on CompuByte POS program
Post by takalani » January 15th, 2009, 1:58 pm
On Innovative CompuByte POS program, you can set the FONT SIZE of your best choice by doing the following:
-->Right-Click on Innovative CompuByte POS Software and click Open; then your Logon screen will be displayed.
-->Cilck on the Parameters button, put in your access code normally 1234; and press Enter key on your keyboard.
-->On the Search textfield, type-in FONT; then click on Entry number 268; then click on the textfield box below Data for this Terminal text. Put in the Font Size you want to use e.g 12. You can put any size you want.
-->Also in entry number 291, click on it; then click on the textfield box below Data for this Terminal text. Put in the Font Size you want to use e.g 13.
-->Then click on the red button with an X, on Top right of your screen to close; then you'll get a prompt that "All terminal parameter info successfully stored", then click OK button.
-->Now when you log into the program; you'll be able to see all the items in the list properly/clearly, when you enter them;(when the cusor is on PLU, you scan the item/ put in the PLU code and press enter).>This is done on parameter 268
-->And with parameter 291; you'll be able to see all the items in the list properly/clearly on the search list(Let's say you want the Ladies Plum shoes; when you type in Plum on PLU; you'll be able to see all your Plum shoes in the list properly.
