Stock Clearing
Stock Clearing
Postby bossalino » May 15th, 2008, 5:52 pm
Is there a way that one can clear the stock quantity and sizes from the systems without using the stock adjustment account. I find that during my years of changing between using sizes and not has left many of my stock quantity at zero but my sizes still remain behind and when the code is re used the old sizes play up.
Postby basit » May 19th, 2008, 8:22 am
The only reason we insist that the stock adjustment account is used as it leaves an audit trial (security of the system). When using the the stock adjustment account you should also minus or plus the stock and the sizing grid. If you use the other method i.e the one from stock package stock print outs (Dos version) and insert INDEX at index then the programmer code it clears the stock values and sizes only.
Hope this helps.
