Stock codes
Stock codes
Postby bossalino » March 5th, 2008, 12:25 pm
Is there any way one can completely remove all history on a specific item when wanting to reuse the code? Its easy to change the description for example if a new items replaces a discontinued one but this leaves the old history behind.
Postby basit » March 10th, 2008, 9:42 am
Usually we prefer that the client does not delete old stock codes for atleast a year; the reason being:- a retained history is important when there is credits to be effected or old lay-buy queries done etc. However if you want to delete the item completely you can edit it and replace it with another code and then delete the old history of the item in a directory called \B0. The file is store according to it's PLU code Example code 2-10 will be stores as 00210.csv - Always the first three digits will be the group where the code is in and the digits after is the location i.e 10 in this case.
