Synchronization
Synchronization
Postby bossalino » February 18th, 2008, 2:20 pm
Does this take place in 2 directions or only from c: to e: drive. Reason i ask is when i travel to Pretoria to do the buying i need the information with me but i dont want to work on my external drive there and then when i get back my local drive is behind my external hard drive. And if i work on my External drive will i have the .net pos or just dos. It would make entering orders much easier if they are entered while with the rep.
I know the best thing to do would be to buy a labtop but i lost to many due to crashes.
Postby basit » February 18th, 2008, 6:44 pm
If you want to take a backup copy to your branches then you dont require the sycro function. You just use the backup.exe icon and do a backup then use the same program (pressing f1 on timer) and restore the infomation. After you done all the work you repeat the process . . Use the XCOPY backup which is easier and quicker.
Hope that's not too confusing . .
More info on backups at :
http://compubyte.co.za/forum/viewtopic.php?t=957
BASit
Confusion.
Postby bossalino » February 19th, 2008, 12:27 am
No its not. i finally started understanding computer language. I even managed to schedule the backup's at all the stores, but i still did not manage to get the email working. Think think it says auto login failure so I'm still work in progress :)
Postby basit » February 21st, 2008, 10:01 pm
who is your ADSL email account provider and what is their incoming and outgoing mail server info.
pop and smtp?
I will then email you a configured mail.bat and m.cfg file
pop
Postby bossalino » February 22nd, 2008, 12:26 am
my internet service provider is telkom but my domain is from sadomain. pop.zaksmalone.co.za smtp.dsl.telkomsa.net
Postby basit » March 2nd, 2008, 1:55 pm
This is how your m.cfg file in \programs should look like
-smtp smtp.dsl.telkomsa.net
-ehlo
-auth login zaki@zaksmalone.co.za (you password in here with brackets)
-from zaki@zaksmalone.co.za
-receipt
-html -file \RAM\MESSAGE.htm
and your mail.bat file should look like this
rem Mail to %1 Subject %2
mailsend @m.cfg -to %1 -s %2
NB : Please also check sometimes your email service provider uses another unique name for login and not your email address !!!
