Downloading the New .Net POS Demo Software.
Post by basit » May 23rd, 2007, 1:32 am
**** Very Important ***
If you have any version of the CompuByte .Net POS version on you PC downloaded or installed from CD after July 2007 then you need only download the 2.4 mb file called pos-upd.exe from the link below:-
http://www.compubyte.co.za/updates/pos-upd.exe
Please note if you have not installed crytal reports version 2008 than you will have to download this file
http://www.compubyte.co.za/updates/pos-demo.exe
first and extract it and then run it first.
Important : Depending on your browser security you may have to right click on the link above and click on Save Target As then type pos-upd.exe and change Save as Type to All files.
This is a very small file and please extract this file into your root hard drive eg: C:\
The files will be extracted into a directory called c:\pos-upd
Please remove any shortcut you have of the CompuByte software on the desktop and remove program from the start menu; after you install the update (running Setup) re-create the shortcut by choosing Start and then All Programs and find www.CompuBytePos.Net right click and send to desktop :)
After you have extracted click on UPDATE in your main Login Page. (It the update button does not exist then open explorer and in c:\pos-upd directory click on update)
c:\pos-upd.
Also very important if you require some Crytal Reports created already and the new parameters; you must copy the \compu directory inside the c:\pos-upd directory to c:\compu ---> This must also be copied to the server's drive if you have a multi-user system ; if the server drive is F: then copy like this using the DOS prompt :-
copy c:\pos-upd\compu\*.* f:\compu
Make sure you read what's new further below . . .
Important: You must load seperately the updates.exe file if you using the Dos Intergrated version and the update.exe file is newer than the one you have last loaded.
This is downloadable from www.compubyte.co.za/updates/updates.exe
Important : Depending on your browser security you may have to right click on the link above and click on Save Target As then type updates.exe and change Save as Type to All files.
New updates moved to this link:- http://compubyte.co.za/forum/viewtopic.php?p=5701#5701
