how to make xp print faster
Need to know how to make window xp print faster at the point of sale
- basit
- Site Admin
- Contact:
xp printing faster
The best option is to set parameter PARAMATER 199 TO 1 then make sure that you have I.bat and not invoice.exe or menu.exe in the last line of the bat file that runs your programs. If you have a single user sytem the file to edit is start-1.bat which is in the \programs directory.
If you have terminals the startup files for each terminal is in the term directory of the server (\term) - Each terminal depending on it's number will have a bat file - Eg. 2.bat 3.bat etc.
Also a further speed up can be done if you follow instructions on this site below : -
http://www.compubyte.co.za/compubyte_de ... inting.php
or this site:-
www.compubyte.co.za/delayed_printing.htm
or this site:-
