How do I not show selling prices on my Document print out
Please always do a search using the search function before you use this forum, to check if a question is already asked
Post by basit »
You go to your program parameter setting from Main Menu and set parameter 193 >
Entry number : 193
║ [SUPPRESS] Enter 1 to show a prompt which will ask whether selling
║ price must appear on any document in Point of Sale (Used in Delivery
║ notes etc) insert 2 if Total must print but not selling prices. Leave
║ blank if not required.
You will note that the selling prices will not appear if 1 is inserted and so wont the totals at the bottom. Thanks to Yunus (micromedia) I have introduced a 2 for a total to appear at the bottom (loadable with newest update)
Hope this helps :D
Return to “This is where you will find most frequent questions asked about the CompuByte POS Software (DOS VERSION ONLY !!)”
